2021 Nascar - Playoff Race 6, Texas
GA_Boater
Lap 25 Comp. Caution. Larson led all laps and Elliott is up to 13th.
GA_Boater
It looked like Joey had contact leaving his stall. His car did a jiggle.
GA_Boater
Finally back to green with Truex taking over in front.
GA_Boater
Now Byron leads with 62 to go in heat 1.
GA_Boater
Leaders are doing splash and goes with 10 to go in the heat. Some get tires.
TWT new leader. 8 to go.
GA_Boater
Debris caution for a quicky.
Larson leads.
GA_Boater
Larson wins heat 2 with Bryon almost beating the 5 to the line.
GA_Boater
Larson leads the restart.
Keso had to pit quickly with left tires going down.
GA_Boater
Caution for Briscoe slapping the outside wall and letting the air out of the rear tire. 57 to go.
GA_Boater
Larson holds the restart lead. 52 to go
GA_Boater
Joey behind the wall with a blown motor. Yellow for clean up and 34 to go.
GA_Boater
Restart and Buescher spins. Only him but some flames from a broken off fuel filler. TWT ran into Buescher to start it. Red flag.
GA_Boater
Back to green. Larso leading. 3 wide and Hamlin has a rub. Larson is leading.
GA_Boater
Hamlin pops the tire. but the body may be OK.
GA_Boater
Under yellow with 19 to go. More chaos on the restart?
GA_Boater
Larso leads the restart. Truex slams the wall! Suarez just nicked the left rear of the 19 to put it in the wall.
