Out of the pits; Larson is off first, then Hamlin Truex Keso Bowman Byron Elliott Joey Busch1 Blaney
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #41 Out of the pits; Larson is off first, then Hamlin Truex Keso Bowman Byron Elliott Joey Busch1 Blaney
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #42 Back to green. Bubba was too fast in the pits.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #43 Debris yellow and Bubba to the pits reporting something broke. Looked under the hood and sent him back out, down 3 laps. Harvick has a rt. front flat after the #43 slid up into him. Out of the pits - Larson stayed out and the rest, Hamlin off first. Then Elliott Keso Bowman Blaney
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #44 Back to green with 29 to go. Larson, then Joey up front.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #45 Joey is leading on old tires and Elliott is there with new tires. 23 to go.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #46 On lap 62 Elliott's new tires beat out Joey for first. 16 laps to go.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #47 Keso took over from Elliott. 9 to go. Maybe I was too quick! Keso led a lap, but Elliott took it back, 4 to go.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #48 With 2 to go, Elliott and Keso are fighting for the lead. Keso leads the final heat #1 lap, Elliott 2nd.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #49 Elliott had a long stop to repair the side skirt bent up by the jack on the first stop. Off pit road at the end of stage 1: Hamlin Keso Bowman Blaney Matt D Joey Byron Bell Larson. Elliott is way back in 29th, but still on the lead lap.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #50 Hamlin and Keso lead 'em to green for heat #2. Keso just led the lap over Hamlin and Blaney to 2nd.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #51 With 50 to go in heat 2, Larson leads Keso, who is being dogged by Byron. With 45 to go, Keso has been dogged and is falling back from Byron in 2nd. I think his tires are cooked. Elliott is 9 seconds back in 14th.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #52 With 38 to go in the heat - Green flag stops are beginning.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #53 20 to go and 4 cars have not hit the pits. 2 cars now.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #54 Larson back in front with 13 to go in 2nd heat.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #55 Larson wins 2nd heat, followed by Keso Hamlin Byron Blaney Bowman Bell Truex TWT Elliott. Larson Hamlin Bowman Truex Bell were the first off pit road.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #56 Larson leads them off, Truex and Hamlin pressure. Caution for Elliott 360 and tags Busch1. Elliott stayed off the wall.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #57 Hamlin leads the restart over Truex and Keso.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #58 Yellow for Almirola flat and wall tag.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #59 Restart and Truex is leading Hamlin. 81 to go.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Mar 7, 2021 #60 65 to go and Hamlin leads Larson.
