2021 Tohatsu 9.9 to 20 hp conversion
Tracker28
Has anyone had luck with this? I was told that this conversion can easily be accomplished by swapping out the ECU’s and removing the restrictor plate from the 9.9.
Has this been true for anyone? If so, did you run into any issues later on?
pvanv
Yes, that is the upgrade procedure. You may need a different gasket at the restrictor. Otherwise, they are identical motors.
