2022 MerCruiser turns-no ignition
oddysea1
My 2022- 350 MerCruiser MPI was running great until yesterday. The engine is turning over but does not show any kind of attempted ignition while the key is deployed to the start position. There are two symptoms -first just at the end of the turn cycle which is usually 6-8 revolutions and as I am turning key to off position I see the oil pressure gauge indicating an increase in pressure and the engine sounds just for a second or two as if it is shutting down although it never started. Any advice is greatly appreciated-Regards Andy
check your MOB switch. it sounds like the MOB switch is tripped which would kill ignition, however allow cranking.
oddysea1
oddysea1
Thank you - I don't have a specific kill switch, unlike my outboard,
unless there is some part of this inboard system I am not aware of. Any thoughts?
may want to look again. its required on all boats under 26 feet. new law went into effect in 2021
ROY WILLIAMS
the electric meter of the ignition module connector, the key is turned turn the key on , and that meter voltage ! did the spark plugs arcing !
also the gasoline of the engine intake manifold ...
QBhoy
hi...this is absolutely odds on to be caused by a very common, simple and always overlooked or dismissed reason. happens so often with these mpi and caught me out a few times in the early days too. I am made more positive by the mention you made around the momentary kick as you let go the key.
So here it is...it's the battery. I will just about bet my salary on it. Briefly, here is why.
These mpi require an absolutely perfect health battery and of the required rating too. If anything less than this...what happens is that despite the engine cranking apparently fine enough...in this situation and with a less than perfect battery, the act of cranking will take all of the power available from the battery and not have enough juice to also power the vital other systems like sensory items, ignition system or even if the cranking rpm is less than a certain speed, the injection system too. it just won't even try....that is, until the brief moment you let go of the key. for a split second, there then becomes power available (because the starter has relinquished its demand) to bring the system to life...but alas, by then its all too late and will only give a slight kick or cough. sometimes you can catch it into life on the throttle...but only if you are lucky. trust me...try another known good battery or boost it. she will almost certainly fire up.
good luck
oddysea1
good luck
stresspoint
i hate to be the one to ask this :) but i have to because of your description.
is there enough fuel in the tank ???.
oddysea1
I fully charged my 2 year old battery's and did place a booster on it. Unfortunately the same outcome the end kick was a little more evident however. The engine is under warranty and hopefully will be checked out on Tuesday. Any other possible issues or advise is appreciated , I will also give a diagnosis and outcome when resolved. Thank you again
stresspoint
Yes half a tank- thank you -regards Andy
can you confirm the 1/2 a tank other than just the gauge reading .
the float in the tank can get bent or stuck in turn giving a false reading to the gauge.
try removing the sender from the tank and get a visual.
you could remove the fuel line after the pump if that is too complicated due to space then you may be able to remove the line from an easier to access fitting.
sure does sound to be a fuel delivery to the injectors issue to me.
2022 with single 350 has to be a boat under 26 feet. I have a 2023 listed as a 280 (28 foot but hull length is 25.5ft) and has a kill switch
2003lsr
Possibly Anti-Siphon valve on top of fuel tank is gummed up/stuck closed.
QBhoy
Unfortunately what you have tried, still doesn’t rule things out around the battery. You’re doing similar to what is so commonly done, then ruling out the battery as at fault. The battery may still take a charge of sorts and you may also have applied a booster pack to it. But if the battery is compromised internally with a bad or weak cell…you’ll still get the same effect. Up to you, but I strongly urge you to either try or borrow a new battery or at least try jump leads. Even the latter may be only 50/50 successful. Perhaps even at the least, you could measure the voltage drop across the battery as you crank the engine. Anything down in the 10’s is borderline and anything less than 10..is a certainty of battery issue and/or 12v system supply, component or earthing/grounding integrity
oddysea1
Thank you all for your advise and counsel--however the problem has been remedied. It was a loosened and compromised terminal post on the key switch. This is a great resource to boaters and I have solved many boating issues as a result of the dedicated boaters that try to help each other. Happy Thanksgiving-Warm Regards Andy
