205 PSI compression??
Brucetafer
all 4 of my cylinders in my aq131a volvo penta have exactly 200-205 psi, wot, 5 compressions, 2 different snapon testers...
does this sound holy crap high????
Don S
Re: 205 PSI compression??
142 to 170 is book value. Makes me think possibly some engine work done in the past 25 years by a previous owner ?
JustJason
My Soobie engine that I built as a high compression engine hit's 210 on my gauge, but I built it that way.
205 on a stock motor is way high, if it runs, you can dry decarbing it and see if it drops, but i doubt it would drop to the 150-170 range. If your running this engine, i'd reccomend going at least 1 colder in the heat range on the spark plugs.
Fireman431
Is it possible that the pervious owner had some head work done? Any evidence of a previous rebuild?
45Auto
When's the last time your compression gauge was calibrated?
Joshua Nichols
Is it diesel?? :D May have had some head work done and had lots of meat taken off the heads?
wca_tim
it wouldn't have to be off by much in terms of a calibration...
Also, a 200 psi cylinder pressure, in the context of the wide lobe angle separation / cam profile of most marine engines doesn't really need to correspond to more than about a 10:1 static comression ratio...
compression gauge a little off, tight engine, a little milled off the head during a good rebuild, block decked, etc... could just great.
How does it run? If good, then just run good fuel and enjoy it.
