2050 Bayliner restoration have to do this one and do it right.
mxcobra
I purchased this boat under the impresion that it needed very little
tilt fixed and tuned up...
Boy was this wrong
Started fiddling with it and all I found was problems...
water would just not go away.
So I started to tear into her and she it rotten all the way through
mxcobra
Re: 2050 Bayliner restoration have to do this one and do it right- need advice
couple more pics
? on drain- really seems to be glassed in deep how do i get it out with out damage to boat?
mxcobra
update on my way o completion
mxcobra
now were getting some were!
mxcobra
hows this looking???
jones56
looking good... looks like alot of hard work
Lt Padgett
Great job so far, looking good
I wish mine was that far along
mxcobra
I am itchy
mxcobra
well I have wood going back in!
Transom glued in the rest of stringers and supports are cut and waiting for glue
I am really woried about doing the fiberglassing in cold wether thogh.
mxcobra
starting to feelgood about the boat.
a got the deck just about cut to fit- got a lot of glasing to do though.
The engine mounts are in and things are feeling very solid:D
jbcurt00
Congrats on getting started on the put back! Good luck, & hope the Colorado winter lets you keep moving forward.
oops!
really really nice mx
kudos
Friscoboater
Very nice work. I love the drain in the front ( I assume that is what the PVC is) and it looks like you are on the way to a nice boat. Make sure you glass the back side of those deck boards.
mxcobra
Cool guys glad you looked-Considering......
A drain it is. cool part is the pipe is 2.5 inch sollid core, and dubles as the middle stringer under the lower deck pieices (the ski locker)
mxcobra
weather is finally warming up-So I am puting glass
getting better at it but still not great - man this stuff is messy
mxcobra
well Im well under way
Deck is in and tabed waiting for foam to arive
I got the transom and bilge glassed (getting mutch better at this glassing stuff)
Going to work on the gelcoat this weekend _
Hopfully next I can start putting the engine and drive back in
Then I may or may not do a test float before foam Probly should for peaice of mind........
mxcobra
Ok foam is in it was a choir in a half but im happy with her.
preaty sure got a compleate fill.
I did use a hot wheels track for a deliver system of the liquid foam work well to make sure I got foam in good and deep.
also stated to rain twice so we had to do some under the cover this is no fun concidering the foam puts of co2 (not Good)
Brenn
nice work on your boat,youre going to be done in no time
