Hello,<br /><br />I have a 1989 20hp Mercury Tiller, manual start with the Walbro WM carburetor. It has the combination pull to choke/turn to adjust idle knob. I at first had a problem starting until I read that the knob is used like a primer and it is actuated several times before pulling starter.<br /><br />Still doesn't start great, cold 2-6 pulls, once warm 1-2 pulls.<br /><br />My problem now is once running it idle's o.k., and low speed operation is o.k., when trying to speed up, past 1/3 throttle, it will throttle up and run fine, then as rpm's climb the motor will cough, spew a cloud of smoke, almost sounds like it's backfiring and kind of choke itself then quit. Someimes it will just bogg down, choke, cough and quit, but more often it does the first description as you try to go to full throttle. The motor has been sitting a while. I'm guessing it might be time for a carb rebuild, but I'm hoping for a simpler answer.
Any ideas?<br /><br />Thanks,<br /><br />DP
