1980Coronado
- Joined
- Oct 8, 2010
- 699
In July I purchased a 21' 1980 Century Coronado, with a 330 Hp 454 cid Mecruiser Inboard.
The tach is a little whacky at times in the low range, but i believe it's close enough on the upper end to tell me I'm over reving to easily with the current prop. The transmission is 1:1. Current prop is stamped 14" Dia RH 15" Pitch, but it's been X'd out and I believe reworked to a 14" pitch. It's a 3 blade NIBRAL prop...old school...not CNC.
Like I said my tach may be giving me bad readings and I need to hook a portable up to it to double check, but just using my ear I know the engine over revs too easily. I'm only getting 35 mph at 4500 rpm which is at about 3/4" throttle. WOT the tach will jump quickly towards 6000. Engine specs say WOT max RPM 3800-4200...that seems low to me but thats what the tag says. My guess is 4500 isn't going to hurt it....6000 will though.
This is my first inboard and I have no idea what prop this boat should have, or what Century recommended. I'm fairly certain the one I have should be switched out. It comes out of the hole well but I have no top end at all. We do some skiing and tubing, and we do load the boat up with people at times. I'm not looking to get the nth degree of speed out of it, but over reving is a concern. I do want to be able to load the boat and still get it up on plane.
Anyone have a clue what Century would have recommended for this boat? A 14" dia 14" pitch is too small for this 454 big block.
