just wondering if anyone else has had this problem with the 2155 bayliner powered by a 3.0l and cobra leg.
just can't get it up on plane. the prop is a 14x13 which is what the boat comes with, but will only get up 3800 max rpm/12mph, with the next size smaller prop it just revs and goes nowhere (14x11) cavitates (4400+ rpm).
hull is clean, boat is not loaded up with any extra weight other than a 9.9hp o/b mounted on the swim grid, 2 persons onboard.
engine compression is 127, 127, 107, 127 stone cold.
new electronic ign, timing @ 8btdc, new plugs, wires, fuel filter...trim tabs help somewhat but not enough.
previous owner says it will do 25mph (on salt water though) with video to prove it.
