220hp Laser warning horn beeps ...
dfrants
on my 1988 220 EFI Laser, when I first turn the key the horn does its test bleeps as it should and stops. then once I start it, its quiet for 2 minutes or so then starts bleeping again. she's not over heating, I have a temp gauge and its well under 140. the oil levels at both tanks are full, not sure what else it could be?
Faztbullet
If it a rapid series of beeps you need to test oil pump output as pump or crankshaft drive gear may have problems....
Faztbullet
dfrants
think we fixed it. there was air in the oil line. I bled the line to the motors tank and so far no more beeping.
