225-175 Will it fit?
Phil K.
My long time Johnson guru has retired and left me for Florida so I'm hoping that the knowledge on this board can help me out.
I have a 1989 225 HP Johnson and I need to know if the lower unit is interchangeable with a 1987 175 HP Johnson.
Both are 25" shafts with trim.
If it is I am planning to buy the complete unit (bad power head) and hopefully get some other items that I need.
ANY help will be helpful. I tried something like this before but between updates and part# changes in the books the project was scrapped.
Thanks for any and all responses.
175se
Re: 225-175 Will it fit?
according to my parts program they use the same drive shaft so I think you could.
175se
according to the parts program they use the same driveshaft so I think they can interchange
Phil K.
Thanks for the info. Also wondering about the water tube, shift linkage and gear ratio. I was hoping to swap over the whole unit instead of a tear down and rebuild.
175se
I believe its all the same .
