225 4stroke won't run
trvs223
I have a 225 4-stroke (f225txrb) that has been run completely out of fuel. I need to know when the fuel pump is supposed to be on and off.Any suggestions on bleeding air aside from schrader valve?
gutshot grouper
Re: 225 4stroke won't run
Rodbolt will read this and offer his expert advise, just be patient.
rodbolt
hello<br /> the low pressure electric will run in the start position. after its running at low speeds, below about 1800, its off every 20 seconds then on for about 20. if you ran the system dry use the primer bulb to refill the vapor seperator. the fuel rail is self bleeding so its no worries. after you insure the VST is full crank it and let off a few cycles. when you turn the key to "on" you should hear both pumps whine for a few seconds. cycle the key switch, after priming with the bulb, several times. it may take several attempts to bleed the air from the rail. just make sure you have fuel in the vapor seperator.
