team shadow
Thread starter- Joined
- Sep 5, 2009
- 53
This is a long one but figure it will help answer future questions. Here goes.
I have a 1995 225 HP Evinrude. It has ran ok last fall when I bought the boat and ok this summer, except for some minor idling problems at times, but would be ok after revving it up a few times in neutral.
Yesterday I ran the boat somewhat hard through some rough water for over a half an hour in Barnegat Bay, NJ than pulled in to the Forked River and had no problems with idling or stalling. After over an hour break for lunch we left and boat ran fine, no idling problems or stalling on the slow ride back to the bay.
Again we had a hard rough ride back but boat and motor ran great for about 30 minutes. Then all of a sudden it bogged down like you were running out of gas.
Every time I would start the motor it would be ok for 5 seconds then idle down to 400 rpms and stall out. I could get it to rev up in Neutral but wasn't revving up smooth or very high and then as soon as you went back to idle it would stall. It did this for about 10 - 15 minutes, then all of a sudden it seemed to run ok and I headed back to the house 10 minutes away and it didn't stall.
This morning I replaced the primer bulb from the tank and the fuel filter at the motor. The fuel separator filter was replaced recently. Took the boat out
and it idled fine on the slow wake 10 minute ride out to the bay and then ran it hard for about 20 -30 minutes and it ran great,seemed like all was fixed and was running better than ever. Then the same problem happened, it bogged down and then stalled out. Kept stalling out this time for almost 30 minutes, pulled motor cover off,pulled air cleaner off all looked well. Then again it seemed ok but I took it slow for about 20 minutes back to the house,
Checked all hose coonections, replaced spark plugs just for GP and to go back to Champions. Took boat back out just before sunset and the same problem, ran it hard for 20 -30 minutes and it seemed good except I thought my RPMs were a little lower at WOT than normal but was still hitting my normal top end speeds, but then it stalled again and kept stalling in idle and idled rough trying to revv it up. About 15 minutes later it ran fine and I rode back slow to the house with no stalling and it seemed fine at house.
Seems like every time now after about 20 - 30 minutes it has this problem.
Like something is getting overheated. Check vent hose and it was clear and seems like fuel up to the VRO is good. Can't tell if this is ignition or fuel related but when it happens it feels like I ran out of gas, like if I was in a car.
This is going to be hard to diagnose if I take it to the shop since it has only been doing it after a hard 20 minute ride.
Any info on what to look for or try next/
