Re: 225 johnson shuts down
What do you have to do to restart it? Will it restart by just turning the key or do you have to squeeze the primer bulb to put fuel into it? Is your warning horn working? This motor should have a fuel vacuum switch on it that sounds the warning horn telling you if you have a fuel restriction problem. If it's an air leak, you'd have to pump the primer bulb to fill it with fuel, before restarting. If it's electrical, you can isolate the engine from the controls. To see if it's in the engine or controls, you could start the motor, disconnect the main wiring at the large red connector, (at the motor) and run the motor. If it shuts down, with this connector apart, the problem is in the motor. If it keeps running, it's in the control area, Just remember that with the red connector apart, you will not be able to shut off or restart the motor, at the controls.
