225 Johson no fuel
bighh7
I have a 99 Johnson 225 and Im getting very little fuel going to the carbs , I removed the pulse line and I can just feel a slight pulse when cranking the engine . Could the reed valves be leaking ?
ONERCBOATER
Re: 225 Johson no fuel
squeeze primer bulb.... if problem goes away while squeezing primer continuously....then look into fuel pump. how long did the engine sit between being run?
