225 Running Hot !!! FIXED!!!
jcory
Re: 225 Running Hot
Re: 225 Running Hot
Gaskets fixed the issue---Boat now runs at 160 temp with a water pressure of about 12psi at 3000rpm---Mechanic says gaskets probably blown for some time by the looks of them--Back on the water---WOO_HOO----look out fish here I come.
langeruds
Re: 225 Running Hot !!! FIXED!!!
naveall43 - You didn't get any answers probably because you hijacked this thread. You will do better by starting your own thread. I know this is a little late, but I just read this thread.
I don't have an answer for you because I am doing my own research on this subject.
Good Luck!
The correct tstat opening is around 145 degrees. I may be mistaken but doesn't the gearcase with the bullet holes ram pick up use the volumetric impeller, I remember you shouldn't swap the alpha centrifical impeller for mercruiser volumetric not sure same for outboard maybe?
Faztbullet
You can not interchange the impellers(OB or MC) as they are a different size and use a different impeller housing and lower unit casting. That the reason OB's using the "floppy" impeller have lower pressures.
