23 raker or 23 renagade ? problem with hub
GOTFIVE
i just picked up a 23 renagade 4blade i tried to put in on with my thrust washer from my 24 raker the top washer of the prop the teeth will not reach it what do i do is there a differant thrust washer there is also a space between the prop and the lower unit is there a weed ring like the mercs thanks anthony NY
Dhadley
Re: 23 raker or 23 renagade ? problem with hub
Yes, OMC used a washer for the 3 blade props and a different one for the 4 blade props.
