235 Sea Drive
rfischer63
Will A power head from an OMC 235 Sea drive (1985) bolt onto a 150 Evinrude
(1986)
rfischer63
Re: 235 Sea Drive
I would be getting complete sea drive, is there any way to make it work if i have both complete units?
Joe Reeves
Re: 235 Sea Drive
Notice the shape of the 235hp exhaust baffle plate assembly between the cylinder heads...... the manner in which it protrudes outward.
Notice that the 150hp baffle plate assembly is flat.
The adapter plate on which the 235hp powerhead sits is of a different design so as to accept that extended baffle plate assembly of the 235hp model.
You could use either powerhead you wish to but only if you incorporate the proper adapter plate...... or the entire exhaust housing (housing between the powerhead and lower unit) to match the powerhead you intend to use.
My previous answer pertained to simply moving a 235hp powerhead to a 150hp adapter plate (or vice versa) which obviously would work.
rfischer63
Re: 235 Sea Drive
Thank you, that makes sense, i thought there shoud be a way, Thx Ron
