24' Pontoon-75HP Mercury or 90 HP Suzuki?
BC71
I am looking to purchase a 2009 24' Tahoe Pontoon with 25" toons.
My current motor options are 2005 75 HP Mercury or a 2000 90 HP Suzuki--both engines are 4 stroke.
The reason for such large engine is because we want to pull the occasional tuber or knee boarder.
Looking for any advice on those engine choices...
THANKS!!
sfy
Re: 24' Pontoon-75HP Mercury or 90 HP Suzuki?
go with the most power you can afford. its better to have a larger engine running at lower RPM's than to have a smaller engine running at or near WOT consistently. and as for pulling people, bigger is better. if your boat can handle a 115, or larger, go for that.
you never hear anyone complain about having to much power, but you will hear lots of people say "i wish i had more power"
Bearfan
We need to put a sticky at the top...All motor questions for pontoons will be answered with one of the following:
1. The bigger one
2. The biggest one your boat is rated for
3. The biggest one you can afford
rogerwa
Go for the 90. I think the statement about "no replacment for displacement" applies here.
I have a 25' that I bought with a 40hp. it moved it along OK but I popped a 90Hp on there and it was so much more pleasant to be able to cruise at a nice speed with out the motorwinding out at WOT. I now have a comfortable cruise at 3000-3500 RPM.
You will not see a proportional speed increase, but the benefits will definitely be noticeable.
Jeep Man
I assume both motors are long shaft. Regular short shaft motors will not work on a pontoon. Also bigger props, bigger gears help push a toon better.
CaptainHook
Of course I would say go for more power, but take into consideration the fact that botha re used, so how many hours, how well maintained, etc....
You don't want to be replacing a motor!!
Topol_86
Only because they're 4-strokes. 2 stroke outboards are designed to run 3/4-WOT, running lower RPMS especially if towing someone damages the engine.
pushnwood
I had a 24 ft. JC with a 115 on it and it was way underpowered! Go with as much HP as you can aford.
