24 volt or 12 volt system?
Tex Aggie
1999 Johnson J90 PLEEB
I also have a trolling motor on the boat. i heard that it needed two batteries hooked together for that (neg to pos, pos to neg), then hook the cable leads for the trolling motor to the battery.
I just didnt want to get too many volts to the motor if its not 24 volt.
Joe Reeves
Re: 24 volt or 12 volt system?
For 12 volts from two 12v batteries.....
Connect the two negative terminals together, Ground cable to trolling motor.
Connect the two positive terminals together, Hot cable to trolling motor.
boobie
The two batteries you have hooked in series for the 24 volt should go to the trolling mtr only. You need a seperate 12 volt battery just for your outboard.
Joe Reeves
Just re-read that first post.... sounds like that could be a 24v trolling motor if the instructions state connecting neg to pos. Check into that Tex to make sure of what you need.
daselbee
If you wire it like you say, you will have one major spark/arc when you make the last connection.
The proper way is: trolling motor neg to neg of batt 1, pos of batt1 to neg of batt2, pos of batt2 to trolling motor pos.
JimS123
There are 12v motors and there are 24 v motors. Put 24 on a 12 and you'll need to buy a new motor.
Since you didn't give a make or model # nobody here can answer your question.
Go read your owner's manual.
F_R
Honorary Supreme Mariner
Say what??? For 24 volts, ground motor to negative post of battery #1. Motor's positive cable goes to positive post of battery #2. Finally connect the two remaining battery posts together. This is called two 12V batteries connected in series, and produces 24V.
What Joe just described is two 12V batteries connected in parallel, and produces 12V, with twice the capacity as one 12V.
Now....You have to tell us what your motor requires, 12V or 24V. We can't tell from here.
Tex Aggie
i inherited this boat, and i am trying to learn...
i dont know what the motor requires. thats why i was asking.. it is a 1999 johnson 90 hp J90 PLEEB (like other post said)
i will try to take pictures and upload what i have.
This is what i have:
there are the main battery cables that hook up on the battery posts for the motor. There are separate cables there that just have ends to connect to a bolt size connection on the battery with a wing nut.
the trolling motor has a plug connection at the front.
I assume the trolling motor needs 24 volts. so, those leads that connect on the smaller battery connection need to connect to which battery? i need to connect two batteries together only for the trolling motor?
F_R
I know what you said and why you are asking. I have looked several times, thinking I'm missing something. Nowhere do I see any clue as to make or model of your trolling motor. It is impossible to give you an answer without knowing what we are dealing with.
Now, hopefully having cleared the air, let's start over. What kind of motor do you have?
Captain Caveman
You need a primer on how all of this works. The first thing to keep in mind is that all boat batteries are 12 volts. Your main motor, the 90hp Johnson, requires one 12v battery to start...exactly like your car. That battery is typically located in the back of the boat near the big motor. That battery is designed to start your big motor and run your accessories but should be kept well-charged. Your big motor has an alternator (just like your car) that keeps that battery charged when the big motor is running - but only at speed, not at idle.
Unlike your big motor that just needs a 12v battery to start, the trolling motor actually runs off of the battery. Therefore your trolling motor requires a different type of battery, called a deep-cycle battery. Deep cycles are made to be run down to empty and then recharged. If you have a 24v trolling motor then it needs two deep-cycle batteries just for itself. Those batteries need to be connected in series. You'll connect the negative cable that goes to your trolling motor to the negative post of one deep-cycle battery, and the positive cable to the positive post of the second deep-cycle battery. Then you run an 8-guage battery cable from the positive post of the first deep-cycle to the negative post of the second deep-cycle. This is how a 24v system runs.
If you only have a 12v trolling motor, you have the option of running it off either one 12v batteries or two 12v batteries. If you run it off of two 12v batteries, you connect them in parallel so that it's like you have a big 12v battery that lasts twice as long. To do this, you connect the trolling motor cables to the positive and negative terminal of one battery. Then you run 8-guage cables from the positive terminal of the second battery to the positive of the first battery, and the negative terminal of the second battery to the negative of the first battery.
So if you do indeed have a 24v trolling motor, you'll need three batteries in your boat. The first battery starts your main motor and likely runs your electronics (depth finder, GPS, lights, bilge pump, etc.). The other two batteries will be connected in series to create 24 volts for your trolling motor.
Hopefully this helps.
p.s. Since your trolling motor doesn't have an alternator like your big motor, you'll need to charge the deep-cycle batteries used to run the trolling motor. You can buy a battery charger and charge each of the deep cycle batteries after use. These days, many people use bank chargers. You would need a 2 bank charger for your 2 batteries. This essentially allows you to just "plug in" your bank charger and it will take care of all the charging.
Tex Aggie
Sorry, i was misunderstanding the make and model question
the trolling motor is a Minn Kota Riptide, i believe it is 74/B saltwater series.
