25 hp Evinrude fuel pump isn't working
eddie_m
My 1977 25 hp Evinrude stopped pumping fuel, the motor will stay running if i pump the gas line bulb . How does the fuel pump work? Thanks
Barnacle_Bill
Re: 25 hp Evinrude fuel pump isn;t working
You can get a kit and rebuild it. Its pretty easy and not very expensive.
Monte1961
Re: 25 hp Evinrude fuel pump isn't working
It works off the lower cylinder by pulsing. If the diaphram has a tear, small hole or has gotten hard over time, it won't work properly. Hope that answers your question!
eddie_m
So a rebuild kit is the way to go in this case, i will try this and see what happends. Thanks Alot
eddie_m
i rebuilt the pump and its still not pumping so i bought a new pump an still pumping weak?
Monte1961
what do you mean by weak? If motor will run good at wot, then ok! post back and let us know!
