mckinney004
Thread starter- Joined
- Jan 26, 2016
- 46
I've always wanted a jet outboard, and finally purchased a used 1974 evinrude 25 hp with a jet conversion on it. I know jets lose about 30% of their power after the conversion, leaving this motor actually in the 15-20 hp range. I normally run an 18 hp mercury on this boat, pushing it about 25 with two people and a tackle box. That being said, I expected similar results with this jet.
Today I took it for a test run. Absolutely disappointed. I honestly think a 9.9 would outrun me. The boat is a 1448 fairly light weight riveted boat. We don't have much big rock here to put a hole in the boat, mostly just shallow gravel bars, so I'm not too worried about the thinner material.
I really think I should be getting substantially more power than I am. Any suggestions? I don't have it raised quite as high as it needs to be. Today was a test run to see how it performed and ran, so I haven't adjusted the transom yet, but I had the motor within 2 inches of where it needs to be permanently mounted. I really don't see that causing me to run half as fast as I expected. Almost the entire jet housing was out of the water, so really the only extra drag was from the foot of the jet... not that much area. I've seen some videos of these newer 20 HP merc jets on 14 ft boats and they scream.
