25 hp evinrude rough idling issues
spacemonkey77
OK so you guys helped me out on here quite a bit a while back. I certainly appreciate that. I have a 1979 25 hp Evinrude model 25904r. It’s a 2 stroke pull start. Previously I was having an issue with the engine running rough at idle but then smoothing out after it warmed up. I thought it was a temperature issue because I was only noticing it during cold weather. However since then the problem has resurfaced even in the warmer weather.
The thermostat is brand new. The coil packs and powerpack are both new! The carburetor has been rebuilt and cleaned a number of times, And I’m fairly certain it’s still clean. It has brand new gas at 50 to 1 mix! Compression was 120 psi each cylinder when I checked about five months ago.I will recheck it again
when I first crank up the motor it runs real rough and it even bumps fairly hard sometimes! It feels like it has no power and even sounds different than normal idle! What’s strange about it is that once I put it in gear and throttle the engine up it will hesitate and surge and then kicks in and runs fine! When it’s first cranked it’s almost like it may be running on one cylinder, possibly! But then the second kicks in and I have no more issues after that until the next cold start. It’s almost like something may be stuck and then when I apply power it un sticks and runs normal! Even when dropping back to idle! I have checked the spark in the past and done a cylinder drop test and everything seemed fine!
could this be the reed valves? Maybe something electrical? I would think if it were electrical in the problem would persist once returning to Idol , but maybe I’m wrong!
Thanks again for your help!
Bosunsmate
Did you do your drop test when it was not running right?
How do your sparkplugs look?
spacemonkey77
No because I can’t ever get the problem to reproduce when i have it in a tank. It always happens when I’m launching to go fishing. I’ll try again tomorrow and see if I can. I suppose I need to pull the cover and do it on the lake when I notice it. It doesn’t happen every time. It’s sporadic!
the plugs were clean and dry last I checked with a warm brown tint. I’ll try and run it tomorrow and check again!
spacemonkey77
Went and pulled the plugs. Little dirtier than last time I checked! Left is bottom right is top
Bosunsmate
Might be something to do with the float and needle valve. Give the bowl a tap with like the back of a screwdriver when at the ramp and see if that fixes it, otherwise keep your investigation up.
Sometimes tilting a motor up and driving a boat to the ramp or home can do temporary things to the inside dynamics of carbs
