25 hp mariner lube leak
redsrider
I have a 96 mariner 25 hp. Noticed black oil on floor. Found it is coming from exhaust, not oil or vent plugs. Changed lube it is still leaking. Engine has not had a lot of use or been misused. Not a mechanic but think it is a seal. Can anyone give me any advise. .
GA_Boater
Is this a 2 stroke?
Smell the oil. If it has any gassy odor, it's unburnt fuel/oil. Has the motor been running OK?
redsrider
Yes it is a 2 stroke. Do not notice gas smell. When on the water engine runs great.
GA_Boater
When you changed the lower unit lube, any water in it? If no, then it probably is unburned fuel and normal.
If a 2 stroke is running a little rich. it can do the drip out of the prop, especially if you do a lot of low speed running.
