floatmiboat
Thread starter- Joined
- Sep 4, 2010
- 90
Hi,
I have a 97 merc 25 hp electric start with remote controls that I've had various starting problems with. Recently I went out fishing and when I went to start it up I got nothing if I turned the key, the battery is good, the starter and solenoid are fine and I read 13 volts between the battery ground and the large red terminal on the solenoid but nothing to the small red terminal when I turn the key. It starts fine if I use the pull cord with the key turned on and if I jump between the battery and the small hot solenoid terminal it will turn over fine too. Does this sound like a bad wire between the ignition key and the solenoid or could something be at fault with the ignition itself? Thanks
