25 hp prop
mattyv
hey guys,
where could i get a different pitch than stock prop for my 1975 25 hp evinrude? i have the motor on my saturn inflatable and it has plenty of bottom end but really screams at the top since it is such a light boat. i know i can get some more mph out of it with a more aggressive prop. thanks in advance
mattyv
Re: 25 hp prop
oh wait i think i just found a place....does anyone know the stock pitch?
K.P.
Re: 25 hp prop
There is no such thing as "Stock Pitch". The size of the the prop is stamped somewhere on the prop or the model number is which will lead you to the prop pitch.
BF
Re: 25 hp prop
not 100% sure, but I think the "standard" pitch would be 10"... I recently replaced my 25 hp 'rude, but I had a 9" on it pushing a 16' aluminum utility boat... handled a load well. I also had an for 11" on it, but anything except an empty boat and it was slower than with the 9". 10" might have been the best of both worlds, but not what I had.
So, if your rig is really light, MAYBE an 11" would be right. Yes, you should check what pitch your current prop is... maybe it's an 8 or 9" in which case maybe you would want to try a 10".
good luck
mattyv
Re: 25 hp prop
ok i pulled the number off the prop: 012013 which according to iboats is already an 11 pitch
http://www.boat-props.com/propeller..._id=30&**********=702277269&*******=937262891
anyone know where i can get something higher?
the boat has plenty of acceleration and gets out of the hole quick even with three people (prob around 450 lbs) dry weight of the boat is only like 150 lbs. rough calculations....the whole set up with three people, engine, gas etc is about 750 lbs
mattyv
Re: 25 hp prop
i found a 12" online but they want 114$ for it....how much of a difference should i get?
jimmbo
Re: 25 hp prop
Roughly same top speed with poorer acceleration and lower rpm @ WOT
steelespike
Re: 25 hp prop
You shouldn't make any prop changes without a tach.You could shorten the life of the motor,waste fuel etc.A tiny tach is reasonable,easy to install and fits any 2 cyl. 2 stroke without regard to stator poles.Guessing rpm by sound could be motor suicide.
