american angler
Thread starter- Joined
- Oct 17, 2008
- 4
hello all
i have a 1974 evinrude 25 hp tiller 2 stroke. had it out on the lake and it seemed to run great. i had allways idled down to the start poss at the end of my move, then after a few restarts the motor started at full rpm
screaming hi rpm's, i tryed moving the tiller handle with no change what so ever i had to take the cover off ( in a hurry ) grab my oar and pull the spark plug wires off ( yes theres no kill switch ) i will be adding a kill switch
when u turn the tiller handle and that plate under the flywheel moves does that have a internal return spring ?? that may have broke and mabey that plate is getting stuck in the wide open poss ??
i was able to push the plate back and get the motor started at idle but was afraid to go over half throttle for fear it would do it again which it did do again at start up in nuteral .
any help would be great
AA
AA
