I have a new 2004 Johnson 25hp short shaft motor. I have oem 5" extension made by OMC in 1986. Comes with engine/exhaust tube rubber mounts and a gasket for between the powerhead and exhaust tube. Is it necessary to pull the powerhead and install these mounts or not and go with the other parts only, new drive shaft, shift shaft, water tube , mid section spacer, and extension tube?
