jims plan b
Thread starter- Joined
- Oct 4, 2005
- 159
Alright let me get started ...I have a 25 johnson model number 25R76E I have no idea how long it has been sitting but it is a clean as the day it was new. I have installed a new impeller and spark plugs and have ordered a fuel pump kit and a carb kit.
just for fun i tried to start it to day... it scared the hell out of me when it started on the first pull (that was the last thing i expected ) Now... it will only run at a fast idle and will only run for about 2 minutes then shut off abruptly and will not restart right away. The heads are not to hot, I can place my hand on them and hold it there.
there is spark on both plugs but the lower plug does not seem as strong as the top plug I ran it for several min. then after it shut down i pulled the plugs ...the top plug is brownish black and dry and the lower plug is clean and wet.
I also noticed a very small water leak at the head gasket just below the half way point and above the lower plug on the left side.
i will install the fuel pump kit and rebuild the carb when the parts come in and see what happens from there but the spark plugs and the water leak is a concern .....any thoughts ?
Ok i got the head off with just one bolt giving me some trouble. cleaned every thing up and am ready to put it back togeather. There was a small amount of water in the lower cylinder is the head the only place that it could leak into the cylinder or could it be invaiding from the exhaust side as well ? I will also need to know what the torque is on the head bolts ...the carb rebuild will be done tonight as well as the fuel pump kit...I think i am gaining ground on this thing with a little help from my friends on here ...thanks for the help
