goblerblaster
Thread starter- Joined
- Dec 26, 2011
- 180
My 1987 25 Mercury will start and run fine using the rope pull. When I use the electric start button, I can hear the solenoid click and the starter gear will engage the flywheel but most times will not turn the flywheel. I have replaced the solenoid and starter but same problem exists. The battery is fully charged and holds a charge. Sometimes when I hit the button the gear on the starter does not engage -or even move, but the solenoid clicks. In messing with it, I have noticed that the flywheel stops in the same location in its revolution- nearly every time. I can move the flywheel manually an inch forward or backwards and then -when I hit the starter button- the starter will engage and turn the motor over like it is supposed to.
I have swapped the battery from my other boat-that has a 115 Evinrude- and when I put that battery on the 25 Merc- same issue continues. Again, no internal engine problems that I can determine, since it runs, idles, accelerates, great when started with the rope.
Any suggestions will be most appreciated.
