25' Sea ray questions. Underpowered?
Fordiesel69
Looking at a 1982 25' Sea Ray Sundancer. It has the 260HP 350 chevy / mercruiser in it. It is a MC-1, R, or MR outdrive as it is not the shape of the alpha.
Looking for a best guess weight, estimated cruise / top speed, and if this is enough engine for a boat of this size. I can tell you the boat feels very heavy duty and has all original floors. So I assume it weighs a lot.
Can a E-350 single rear wheel passenger van haul a boat of this size safely up and down the ramps? Or do you need to have a dual rear wheel axle?
Bifflefan
Re: 25' Sea ray questions. Underpowered?
The drive is a 1 drive not an R/MR/Alpha. 1983 was the first year for the R drive.
Boat weighs 4650 without the motor. probablly 5300 lbs total.
25 mph seems like a good guess.
It should be enough engine. Its never going to be a speed boat if thats what your asking.
You E-350 should haul it fine. You dont need a dually. I haul 11,500 on a single wheel F-250. Its a little twitchy sometimes but works well.
lime4x4
I have a 1986 268 weekender with a 350 engine. With the original engine it wasn't a speed demon. topped out at 27 mph. Took about a minute to get up on plane. Switch out engine to a 1999 350 vortec engine with a 15 3/4 x 15 mirage plus ss prop. Get up on plane now fully loaded in under 15 seconds. Perfect water conditions and drive trimed just right i can hit 39 mph according to the gps
Fordiesel69
What HP rating is the vortec?
lime4x4
around 300 hp but it makes around 350 ft lbs of torque esp at the low end where it's needed
Fordiesel69
Lime,
I have never been on a 25'. When you are cruising in the 20 's does it feel real slow on a boat that big?
smokeonthewater
my 26' carver cruiser with flying bridge would hit 30mph on gps with a tired 2 barrel 305 (mercruiser 898 rated at 200hp) in it. I run a 16x14 prop and it planes almost instantly and cruises very nicely at 17-25 mph.
Factory test chart says 40 with stock 260 mercruiser and 15x17 prop.... I'll know soon enough as I just built a 350 for it...
26aftcab454
sounds about right- 1984 26ft Wellcraft 1996 w/7.4Mercruiser /Bravo3 runs 43mph at 4600rpm- cruise 3600 rpm 30mph- you gotta dog 28mph .
