reelfishin
- Joined
- Mar 19, 2007
- 3,050
I've been looking for a good 20" shaft 100 to 150 HP outboard for some time now, today I came across a near mint 1974 Evinrude 175 HP V6 but it's a 25" shaft. There are two problems, the boat is rated only at a 150 HP max, and this is a 25" shaft. If I use the lowest set of holes, it the anti cavitation plate will set about 1/4" or so below the lowest point of the hull. Second, I have a non running 150HP parts motor from 1974, both of these motors look nearly identical other than the HP designation, can I detune the 175 enough to be safe? What were the differences in the 150 and 175? They both weigh within 10 pounds of each other so the 175 isn't adding any more weight than the 150 would, and if I can mount this high enough I don't see any reason why I can't make it work?
I got the 175 for free and it came from a clean, running boat. I ran the boat myself to the dock where we trailered it away. The hull on that boat is just not what I want so I plan to pull this motor for use on another boat.
I know that overpowering a boat can be dangerous, as well as illegal, but I don't see the real problem here since weight or stability won't be an issue.
I also don't often run my boats hard, I never run at top speed, there's just no room to do so here since I fish mostly the river and back bays.
I just hate to not put such a clean motor to good use. I'd like to here some other opinions here on both the 25" shaft on a 20" transom and the 175 vs 150 hp issue.
