88seville100
Thread starter- Joined
- May 16, 2009
- 47
This is the second time the motor is doing this. The first time I was cruising just fine and then the rpms dropped to 2500 and wouldnt go past it. I checked the oil tank for the oil injection and it was kinda low so i added some. It ran great after that so i figured it was like a low oil saftey governor or somehting.
But then yesterday it did the same thing when i was cruising, but i topped off the oil and no change. if i put the motor in neutral it will rev up just fine, but in gear it sounds like the rpms want to go up, but it seems like there is some kinda governor holding it back? What do you guys think?
btw its an 88 100hp merc on a sea ray seville. i also checked the spark a few weeks ago with a timing light and all cylinders were firing.
