OK, <br /> <br />Well last spring you all helped me out getting a 69 E-rude running that had been through a fire. Well I have finished restoring the outside and the indside is mechanically sound. The problem that I am having is that when I start the motor in Neutral it doesnt want to start real easy. If I was to put it into gear and pull and throttled the engine a little more the engine fires on like the second pull.<br /><br />Now here is the question that I have, I dont think that the motor has a idle screw like a old motorycle, I am thinking that this is all done by the amount of air intake in the carb system. How can I idle the motor up so that it will stay running in the neutral position. <br /><br />Is this something that can be fixed with a slight adjustment or is this something of a bigger problem that needs to be looked at!<br /><br />Thanks Guys!<br />-LD
