25hp 2stroke mercury help
boater1234
Hello to all.I have a huge dilemma to figure out here.I made a mistake once again and made more work for myself.I just wanted to take a screw or bolt of one engine to see if it fit in an older merc to compare them,figured no harm as they came out easy.When i went to put the bolt or screw back in the 25hp copilot holes as you can see on the picture it started to go in crooked and i turned it a few turn to tight thinking it may go in alright but then decided to turn it back out because it was going in to hard,well the darn bolt broke off,all this over something i should have never played with in the first place put i was curious to see why 2 different yr mercs had different copilot screws.My 20 has so much play side to side because it's a collar bolt and the 25 has no collar so i wanted to see how the 25hp screws would fit into the 20 and see if it eliminated the play which it did.Now i have a broken bolt and don't know how to tackle this correctly without really screwing this up and need help because a whole new swivel bracket is big bucks and the labor forget it.I have to rip the whole top end of the outboard to get to it for a stupid screw up if i have no other choice and that may be something i'm no prepared for yet
Should i bring it to a marina and let them do it or can anyone help on this.I don't want to make a huge mistake of trying to drill it out when it when in crooked,the threads i would assume are shot in the screw hole now anyway after doing that.I figured if i can at least get it out i can try a new bolt and maybe retap the hole or i read i could use a shorter screw because it still catches and would tighten up fine,or possibly use a bit of a larger screw if it would fit.
First thing i need to do is get the bolt/screw out without damaging the aluminum or it's big bucks.I'm sure it's at least a $500-$1000 job through a marina because the power head must come off,etc.....It's a mess over one screw that is all i know.The worst part is the motor only has 3hrs on it and has been stored up for 14yrs of no use,it hasn't even been broke in yet.Any help on what i should do here would be extremely helpful.I have a great working 20hp so if i have to hold off on this for a while i will and tackle it in the fall here because it's hotter than heck here and sucks to work in it but if i can fix this i will.
I'm hoping this has happen to someone else that can help,thanks.
boater1234
No Title
flyingscott
If enough of the bolt is sticking out grab it with a vice grip and heat it with an oxy acetylene torch Otherwise Drill it and helicoil it use a cobalt bit and go slow. Go slow because if the drill walks it will go right through the aluminum.
jimmbo
To do the repair properly you are probably going to have to take it apart. Then you can drill out the bolt with a drill press which would be far more precise and done starting with a smaller pilot hole. Unless there is a substantial amount sticking out to grab with vice grips, Then you still have the issue of trying to tap and install the heli-coil, it just doesn't look like you have a straight on shot.
roscoe
I recognize that part, a real pin to get at with any tool or wrench.
It will have to come apart to get at it.
boater1234
I took it to a machine shot,I hope he can fix it. To take it apart would involve taking the whole top of the engine apart that I have no experience with and if I were to do that I may as well replace the part. The guy I took it to is doing it with the whole engine in tact. He is going to drill it out and tap it if possible, he's not a fan of heli-coil. I don't care how he gets it done as long as it's strong again I'm happy with it. The bolt or screw is flush with the aluminum, believe me I would of got it out with a vice grip had It had something to bite to. I hope he can fix it,he said he could do it. All this over taking a screw out,man,unreal.
