25hp, Can't keep running.
koolerb
A friend of mine Just bought a used boat with a 25hp Johnson or Evinrude, late 90's I think. (Can't rember) He says it will start right up, but will only run for a short period of time. I'm thinking sticking float. It's using whatever fuel is in the float bowl, then starving when the bowl is empty. <br /><br />Am I on the right track?
BoatBuoy
Re: 25hp, Can't keep running.
Probably not the float, but the fuel pump. See if it can be made to continue running by pumping the fuel line bulb.
D
DJ
Guest
What happens to the primer bulb on the fuel line?<br /><br />It could be as simple as a fuel tank vent.
tashasdaddy
or the hose is on backwards. the arrow points toward the engine.
koolerb
There I go overthinking things again. <br /><br />Thanks
