Jeremy1986
Thread starter- Joined
- Jan 2, 2010
- 69
Hello, I have a 1988 johnson 25hp that had 120 psi in both cylinders. I went to change the spark plugs and I over tighten causing it to strip out. I bought another head cylinder and had it shaved down and new gaskets. Now I'm only getting 75 psi in both cylinders. I torqued the head to 240 in pounds. I haven't started the motor. What can be causing the low compression? Thanks for the help. Jeremy
