25hp Johnson Long Shaft to Short Shaft Conversion
jdot68
Hi,
I have 1990 Johnson 25hp and it has a long shaft conversion kit on it. I need to convert it to a short shaft. Does anybody know what parts I need to do this? Is there a kit available somewhere or do I need to buy the parts separately?
reelfishin
Re: 25hp Johnson Long Shaft to Short Shaft Conversion
Depending on whether it has a one piece shift rod or an extension, you will no doubt need he shorter drive shaft. I just did my 1975 25hp, all I needed to do was lose the shifter rod extension, water tube extension, and install a short shaft drive shaft. The hardest part was finding the drive shaft.
0154014
I have a 1990 25hp johnson short shaft and I am looking for a long shaft conversion kit. would you be interested in exchanging parts?
tashasdaddy
if you are, do your negotiations, via the Private message system, or email, not on the open forum.
Kevin612
Hi,
Hi jdot68,
I have a standard that I want to cover to a long shaft...are you interested in exchanging parts? I did this on a 20hp already and it's pretty easy. I think the parts are the same but we will need to verify. Thanks
