My son has a '00-'01 Johnson 25hp outboard that is acting up. Ity doesn't want to idle well and appears to be misfiring. When you get the boat on plane with WOT it has a slight power loss. You can get the engine to increase RPM's by about 500 or so by slightly pulling out the choke knob. I pulled the cap off and didn't see anything obvious. I did discover however that it doesn't have a conventional butterfly type choke in the carb bore but instead uses some type of enrichment solenoid. Can anyone steer me in the right direction? Many thanks!
Mike
Mike
