flyingscott
- Joined
- Apr 8, 2014
- 8,343
DON'T PUT WIRE IN THE HOLE. On the base of the carb where it bolts to the motor is the exit hole for the primer. Use compressed air to blow through that. I brought visual aids. In pic #2 bottom of the primer you take the bolt,spring and ball out you will see a wee hole. That is the primer outlet to the motor. The fuel travels up the side of the bowl through the hole in pic #1 through the carb body and comes out the hole in pic #3 with the brass fitting. I use spray carb cleaner to clean that hole. Spray the way the fuel flows.
