boater1234
Master Chief Petty Officer
- Joined
- Jan 6, 2010
- 869
I have a nice 25hp merc as some people know here.I'm having some other issues with it i'm trying to figure out.I'm hoping someone has this engine,It's a 2003 25hp 2stroke merc manual start.
When i go wot and want to come to a fast stop like on a dime just letting off the throttle the motor lifts up but not a ton but i can feel it in the tiller.I took it to my marina and he told me these motors are designed like that in case you hit something it automatically kicks up.So it will do the same on a fast dead stop he said.Everything was working perfect out and in the water.Well i'm hoping someone can relate to this.
It locks in reverse and neutral but no matter what i do it doesn't lock in foward.I'm hoping someone here will tell me this is normal.Also i noticed the exhaust is so close to the water when it gets rough it will go under the water for a second and then out again.This won't hurt anything will it?It doesn't get like completely submerged,it gets some water in it from the rough water and then it comes out.The motor runs like a bat out of hell,it will get it.32mph with 2 big full adults and all the gear is like 800lbs total weight.
Also i'm not 100%sure but i think the powerhead gasket may be leaking or it just may be from water getting under the cowl because it was so rough out.If i had a leak how could i tell,would it over heat or what would it do.I went over 15miles yesterday with it and it ran perfect so it may just be water that got under the cowl from being rough out.
Any help on this would be great,thanks.
