25hp no spark on bottom plug please help!!
toybuilder039
I have a 1975 25hp model#25502B and for some reason I have no spark or very weak at best on bottom cylinder.I have tried switching leads going to coils then i get spark on bottom so I figure coil is good new points condensors even switched condensors but no change filed points cleaned points with contact cleaner and have replaced the pickup coil under flywheel but still has not fixed problem. I really need some advice so please help this thing is getting the best of me.
ultra353
Re: 25hp no spark on bottom plug please help!!
Check your kill switch wire(s) and all other wiring for chaffing, could be rubbed through somewhere. Disconnect kill switch and check for spark.
toybuilder039
I actually don't even have kill switch wires installed and I ran new wires from points to ignition coils thanks for the reply
AlTn
did you switch the lead from the bottom cylinder to the top to rule out something in that bottom circuit?
toybuilder039
Yes I switched the wire going from the points to the coil and I got fire on the bottom then but then no fire on the top.Man this thing has me stumped
boobie
You must have the points set Correctly on this mtr for the system to work properly. And they must be good and clean with no resistance. If I remember right one set of points works for the other for a ground circuit. It was a real horse S**t ignition system.
toybuilder039
I set both set of points .020 gap is that right or is there something else to try. I will check it out tonight to make sure gap is perfect thanks
toybuilder039
Well it was either one of two things not for sure which one though I sanded the pickup coil which was a new one though and I changed the ground wires on the ignition coils which were in between the coil and block to outside of coil I not for sure what worked but I finally have great spark will jump 1/2 inch no problem thanks guys.
