25hp Won't Pee On Muffs
Stamey
My 1995 Rude 25 hp will not pee on muffs but pees fine when the lower unit is submerged. Is this a sign that I need a new impeller?
Thanks,
Chris
mars bar
Re: 25hp Won't Pee On Muffs
Providing you have the muff on the right spot. Last week I put the muffs on wrong, the side with the hose attached was on the side opposite the water intake DUH! I think if you have a good stream your impeller is fine.
hidef
My 35 doesn't like to pee when on the muffs but put it in the water and it pees like a champ. I don't think you have anything to worry about.
Stamey
What sucks though, is that I can't run it in the yard, because it never picks up the water. After I bought it I put a new impeller in it, about 3 years ago. It worked fine on the muffs then, but now....
Maybe I'll try a different set of muffs and clamp them on, for a tighter fit.
Thanks,
Chris
Cofe
The OMC manual says to put duct tape on the 1/8 inch holes that are just below the cavitation plate on both sides. This keeps water from draining out of the leg while on muffs.
Stamey
I'll have to look for those.
Thanks,
Chris
