25r58
camofry
1975 Johnson 25hp , Model #25R58 Sea Horse. Is this a pull start only or can you add a ignition . It has a starter on it but no wiring.
cwhite6
Re: 25r58
Post in the Johnson folder on here and someone will answer you.
CATransplant
Re: 25r58
Yes, that was available with a starter. If there's a starter motor on it, then you'll need a solenoid and the wiring to run the starter.
I don't have a wiring diagram for that outboard, but you can see a blown up parts diagram for all the models of the 25 hp from that year at http://shop2.evinrude.com. Just pull down the list and find the 25 hps for that year.
