25r70 reverse gear
allen.wood
My reverse gear is popping out under high throttle usually when powering off trailer and breaking sheer pins in the prop. Is the entire reverse gear gone or is it something else?
wbeaton
Re: 25r70 reverse gear
If its only happening in reverse then its probably because someone has flipped a worn clutch dog instead of replacing it. Could also be that the linkage isn't set right and reverse isn't fully engaging, but I doubt it.
