260 Mercruiser engine blocks
party barge
Mine is a 95 260 Mercruiser, it has a mechanical fuel pump, 1 piece rear main, all cast 2 bolt main and roller compatible. Does anyone know the origination of this block with GM? Someone told me Caddy Fleetwood from 93 to 96 was this engine but the yard has a 95 there but no fuel pump pad. I wanna parts engine. thanks:D
Haut Medoc
Re: 260 Mercruiser engine blocks
You need a pick up truck engine......;)​
riverjet502
There is no magical "marine" block"... A engine block is an engine block.. Just look for 1 with a one piece rear main seal. No fuel pump pad? No problem use an electric marine fuel pump such as a Mallory. Reason people say go truck block is gennerally they will have the more desirable 4 bolt mains. A 2 bolt main block will due just fine unless you are seaking 6,000 rpm plus, for extended durations. Then you would want forged internals as well as the 4 bolt main.
FreeBeeTony
Think the reason truck blocks/engines are more desirable is because the cam is very close to a marine cam.........not because they are 4-bolt.
party barge
I was told once that GM made the blocks for Mercruiser and added more nickel to them for corrosion protection. I noticed that with this engine of mine that it does not rust inside an actual rust color but a black color instead. I stick my finger in the hole and wipe and all I get is black, no scaling at all and all the deck edges are sharp still....weird
Any way, I know about truck stuff...I was just wondering if this was all true about GM produced blocks for Mercruiser or if Mercruiser choose blocks that GM used in cars and trucks. I'm not concerned about fuel pumps just the fact that a 1 piece rear main block has not been found with a mechanical pump provision anywhere in our yards here or Jeggs. Ya can't get anything near close from a place like Jeggs in a crate form...seems Mercruiser had all these ends tied well.
riverjet502
Yep bought a lot of stuff from Jeggs & summit over the years... I wouldn't sweet the block if it has no boss for a mechanical pump. You would be just fine with a Mallory 4110M electric pump. Crate engines.. There's a thought. I know alot of guys that run jet sprint boats that run the snot out of the ZZ4 350 right out of the crate. It's either off or wide open. Tough little small block for the money...
Haut Medoc
Wrong one.....
You need one piece....
Never mind.....:redface:
