Hi all! I just had to replace my stock prop on my 84 Bayliner Capri with 270 Outdrive. I bought the Volvo prop and when I installed it, I noticed that their is about 1mm worth of play forward and aft of the propeller on the shaft. I have the orginal thruswasher, new zinc, nylon spacer, cone nut spacer and cone nut all installed. Is this amount of movement acceptable or should I shim the prop to stop this movement?
Thanks,
Mike
Thanks,
Mike
