280 drive, Lift question
bgc
Ensign
This is an electric mechanical lift mechanism relay box that is not attached to the shaft...... what is missing to keep it on the shaft?
Bottom of Relay box, note screw ..
Top of shaft where relay box sits...
74bayliner
Re: 280 drive, Lift question
Yeah pirate is right. U are needing the 2 bolts with locknuts.
29? Hex. Socket Screw9593272 $11.85
30? Lock Nut9516722 $1.35
Here is a quick video i made to help you out. excuse my A.D.D. i talk alot.
bgc
Ensign
Thank you to the both of you! and the video was a great help. I have looked at the schematic many times and never noticed "#30 Lock nut"
I was looking for a threaded flange or large washer that the bolts would thread into.
Thank you again,
captmello
Just wanted to add, don't overtighten the bolts. Just tight enough to remove the up and down play in the box. the relay box should still turn freely on the tilt assembly.
Nice Vid, btw.
bgc
Ensign
Thank you for the tip
