1981fiberform
Thread starter- Joined
- Jul 23, 2011
- 18
So right before I went to lake Powell with the scouts last week I noticed a little oil on the trailering bracket and it looked like it was coming off the bottom of the bellow. So I changed the drive oil to see and it looked like it might be a little milky. Didn't have time or parts to do anything but hope for the best. Now I am back from 5 days on the water, drained it to see and it is carmel milky. If I reach up under the bellow with my finger there is oil on both the top and bottom bellow.
Unfortunately, I am in the same predicament again, headed back to Lake Powell to meet up with family and the boat has to go.
So short term I am debating between just going on this new oil for 4 days with a known leak or changing the drive oil every night ( I am getting pretty good at it) . Anyone who has seen outdrives go bad know how risky a little fresh water in the oil for another trip is?
Long term I am ordering big and small bellows, two o-rings and the gasket for the fill screw. The one other post I found had referenced replacing the seals and something I did not understand about greasing zerks while I was in there. Can't you access all the zerks from the outside? Is there anything else I should replace or check while I am in there?
Also, the exploded view of all the gears in the outdrive is a tad intimidating. I am reasonably handy but have never got into my drive deeper than replacing the shift cable. Any chance I am biting off more than I could chew by removing the upper assembly? Thanks to all who share - I have learned and fixed many things thanks to this forum. I will try to take pictures of the job and post for the next guy.
