280 Removal
worntired
Can someone tell me how to remove the outdrive so I can remove the engine? I have the actual drive completely removed, but the thing held in by either 6 or 8 bolts won't seem to come out. How on earth can I get this off to pull the motor? THanks for any insight
David
captmello
If you're trying to remove the clamping ring, there are theaded holes in the ring that you use the same bolts threaded into the holes and tightened to loosen the ring.
worntired
Thanks for the help, but I'm not sure if I understand how to take the clamping ring off. The whole outdrive and engine are coming out for extensive fiberglass repair and restoration. I won't have a chance to look at it until after church, but are there other bolt holes that take the bolts and when I tighten them down there it forces the ring off? I have a couple of manuals, but I'm unsure of how to phrase what I'm looking for.
worntired
Thanks guys, popped right off!!! Now to pull it and start on the resto!
